IPS_GetPresentationValue
 mixed IPS_GetPresentationValue (string $PresentationID, int $VariableType, array $Parameters)
PresentationID
The ID of the presentation, formatted as GUID
VariableType
The variable type for which the value is to be returned (0 (VARIABLETYPE_BOOLEAN): Boolean, 1 (VARIABLETYPE_INTEGER): Integer, 2 (VARIABLETYPE_FLOAT): Float, 3 (VARIABLETYPE_STRING): String)
The parameters of the presentation as key => value pairs, e.g. ['MIN' => 0, 'MAX' => 100]
The preview value of the presentation. The type depends on the presentation and the variable type.
The function returns the value the presentation PresentationID shows in its preview, e.g. in the variable dialog or in the template manager. The presentation defines this value in presentationValue (see IPS_GetPresentation):
  • If a fixed value is defined there (e.g. TRUE for the switch), it is returned unchanged. VariableType and Parameters have no effect then.
  • If PHP code is defined there, it is executed and its return value is returned. In the code, the Parameters as well as the VariableType as VARIABLE_TYPE are available in $_IPS. The parameters are not completed with default values – if the code needs a parameter (e.g. MIN, MAX and STEP_SIZE for the slider), it must be passed.
If the code does not return a valid JSON-encodable result, the function fails with "Invalid JSON for presentation value: …". If the presentation does not exist, the function fails with "Presentation with ID … not found!", for an invalid GUID with "PresentationID … is not a valid GUID".
Together with IPS_GetPresentationFormat this allows creating a preview of a presentation.
// Fixed preview value
var_dump(IPS_GetPresentationValue('{60AE6B26-B3E2-BDB1-A3A1-BE232940664B}' /* Switch */, VARIABLETYPE_BOOLEAN, []));
// returns: bool(true)
// Preview value from PHP code
var_dump(IPS_GetPresentationValue('{3319437D-7CDE-699D-750A-3C6A3841FA75}' /* Value Presentation */, VARIABLETYPE_FLOAT, []));
// returns: float(123.456)
var_dump(IPS_GetPresentationValue('{6B9CAEEC-5958-C223-30F7-BD36569FC57A}' /* Slider */, VARIABLETYPE_FLOAT, ['MIN' => 0, 'MAX' => 100, 'STEP_SIZE' => 1]));
// returns: float(42)
