IPS_GetLiveUpdateVersion
 string IPS_GetLiveUpdateVersion ()
Build date and the first 12 characters of the revision identifier, separated by ", "; on a development version the revision identifier itself ("Unknown")
The function returns a readable identifier of the installed kernel build. It consists of the build date of the kernel (IPS_GetKernelDate) as a date in the format of the system settings and the first 12 characters of the revision identifier (IPS_GetKernelRevision), separated by ", ".
If no build date is available, as with a self-built development version, the complete revision identifier is returned instead - in this case "Unknown".
The version number is returned by IPS_GetKernelVersion; whether a newer update is available is returned by IPS_GetAvailableUpdates.
echo IPS_GetLiveUpdateVersion();
// e.g. returns: 09/15/26, 8edcb65b2750
// on a development version: Unknown
