Legacy Icons
The WebFront uses the Legacy Icons and not the usual icons of the tile visualization.
Icon type
It is differentiated between ‘normal’ and ‘adaptive’ icons. Normal icons do not change their appearance, whereas adaptive icons adapt their appearance to the set variable, depending on the value.
In this way, adaptive icons orientate themselves around the min/max values set in the profile. These are handled as 0-100%. Should it be handled as 100-0%, the term ‘.Reversed’ must be entered into the profile name.
Individual adaptive icons (e.g. Intensity-25), can also be entered directly and are then integrated as a ‘normal’ icon.
Customized Icons included
From version IP-Symcon 3.0, customized icons are integrated via skins.
Further information can be found in the developer’s area as SDK: Skins SDK
Selection in the Management Console
The icon selection in the management console is optimised for the current icons. Still, the legacy icons can be chosen by entering the icon name manually into the corresponding field.
Icon overview
The following icons are contained in WebFront and can be selected at the relevant locations in IP-Symcon. A special case is the icon Transparent. If that icon is selected, other icons of lower in rank (see above) are not displayed. This style element can be used in order to, e.g., not display an icon of a linked category object, even though the category has an icon.
Icons
Adaptive Icons
The following icons are only available from IP-Symcon 5.0/Symcon Mobile 5.0: Bath, Bike, Book, Cloudy, Doll, Door, Download, EnergyProduction, EnergySolar, EnergyStorage, Favorite, Fitness, FloorLamp, Gas, Handicap, Heart, Help, Link, Menu, Pants, Party, People, Presence, Raffstore, Remote, Sink, Sleet, Sunny, Teddy, Tee, Thunder, Umbrella
