HM_WriteValueFloat
boolean HM_WriteValueFloat (int $InstanceID, string $Parameter, float $Value)
Parameter | Parameter that should be set. The name of the parameter can be taken from the data point list or as "Ident" in the tab "Status Variables" in IP-Symcon. |
Value | floating point number that should be set |
Additional datapoints can be taken from the HomeMatic data point list.
If the error message Failure occurs, this is usually due to a bad wireless connection.
// Dim device to 25%. Values allowed between 0.0 and 1.0
HM_WriteValueFloat(12345, "LEVEL", 0.25);
// Set the activation duration to 1 hour. Values allowed between 0 and 85825945.6 in seconds
HM_WriteValueFloat(12345, "ON_TIME", 3600);
