HM_WriteValueInteger
boolean HM_WriteValueInteger (int $InstanceID, string $Parameter, int $Value)
Parameter | Parameter that should be set. The name of the parameter can be taken from the data point list or as "Ident" in the tab "Status Variables" in IP-Symcon. |
Value | Whole number that should be set |
Additional datapoints can be taken from the HomeMatic data point list.
If the error message Failure occurs, this is usually due to a bad wireless connection.
// Set the number of alarms to the value 25. Values allowed between 0 and 255.
HM_WriteValueInteger(12345, ALARM_COUNT, 25);
// Set the number of service to the value 78. Values allowed between 0 and 255.
HM_WriteValueInteger(12345, SERVICE_COUNT, 78);
