HM_WriteValueString
boolean HM_WriteValueString (int $InstanceID, string $Parameter, string $Value)
Parameter | Parameter that should be set. The name of the parameter can be taken from the data point list or as "Ident" in the tab "Status Variables" in IP-Symcon. |
Value | string that should be set |
Further data points can be found in the HomeMatic data point list.
// Transfers the value "Hello World". Any string allowed.
HM_WriteValueString(12345, SUBMIT, "Hello World");
