What can we improve?
Translation is in progress...
Not all topics are available at the moment and content links may be broken.
EIB_DimControl
boolean EIB_DimControl (integer $InstanceID, integer $Value)
InstanceID ID of the device to be switched
Value Dim value date between 0..15 or -7..7
Sends a dim value date Value to the device with the ID InstanceID. Depending on the configuration 0..15 (Standard) or -7..7 (Enhanced) can be sent.
Since this function performs only a relative change of the dimmer, the brightness can not be specified absolutely. It is recommended to create an 8-bit address in order to set direct light levels.
EIB_DimControl(12345, 0);
Deutsche Webseite verfügbar
Go to cart
