DoorIP_Decline
Require: Symcon >= 8.0
void DoorIP_Accept (int $InstanceID)
| InstanceID | ID of the instance of the device to be switched |
If the command could be executed successfully, the result is TRUE, otherwise FALSE.
Rejects the current call to the instance with the ID InstanceID.
DoorIP_Decline(12345);
