DoorIP_SendDTMF
Require: Symcon >= 8.0
 void DoorIP_SendDTMF (int $InstanceID, string $Digits)
ID of the instance of the device to be switched
Digits
Characters to be sent as DTMF
Only these characters are allowed: 0-9, *, #
If the command could be executed successfully, the result is TRUE, otherwise FALSE.
Sends the characters Digits to the current connection on the door intercom instance with the ID InstanceID.
DoorIP_SendDTMF(12345, '*123#');
