smart Irrigation Control
Require: Symcon >= 6.0
Since the Gardena API does not transmit the schedules created in the app, irrigation plans can be implemented using the weekly schedule and the actions provided.
The smart irrigation control device offers various services in IP-Symcon which, for example, make it possible to identify the status of the device or switch the various valves.
Services
An instance can be created for each service using the configurator.
Service Description
General Contains general information about the device
Valve Represents one of the 6 valves of the irrigation control
Main valve The main valve with which all valves can be closed
General
The following state variables are created for this instance
Variable Type Description
Battery status String The status of the device's battery (This device does not have a battery)
RF Link Level Integer The quality of the wireless connection in percent
RF Link Status String The status of the device's wireless connection
Valve
Activity String The current activity of the device
Remaining Integer The time remaining in seconds until the valve is closed
Error code String The last error transmitted
Status String The current state of the device
Open duration Integer The duration for which the valve is to be opened manually
Action String Allows the valve to be opened or closed for a specific opening period
The following actions are available for this instance
Action Parameters Description
Open valve Duration (minutes) Allows the valve to be opened for a certain period of time
Close valve (none) Allows the valve to close
Main Valve
Name Type Description
Action String Closes all valves
Close main valve (none) Allows the main valve to close
