smart Power Socket
Require: Symcon >= 6.0
The smart Power Socket offers various services in IP-Symcon, which make it possible, for example, to recognize the status of the device or to switch the adapter.
Services
For each service an instance can be created with the configurator.
| Service | Description |
| General | Contains general information about the device |
| Power socket | Represents the power socket that can be switched |
General
The following status variables are created for this instance
| Variable | Type | Description |
| Battery status | String | The status of the device's battery (This device does not have a battery) |
| RF Link Level | Integer | The quality of the wireless connection in percent |
| RF Link Status | String | The status of the wireless connection of the device |
Power Socket
| Activity | String | The current activity of the device |
| Remaining | Integer | The remaining time in seconds until the socket is switched off |
| Error code | String | The last error transmitted |
| Status | String | The current state of the device |
| Activity duration | Integer | The duration for which the socket is to be switched on manually |
| Action | String | The action which should be carried out |
The following actions are available for this instance
| Action | Parameters | Description |
| Switch on the socket | Duration (minutes) | Enables the power socket to be switched on for a defined period |
| Switch on the power socket permanently | (none) | Allows the socket to be switched on permanently |
| Switch off the socket | (none) | Allows the socket to be switched off |
