smart Water Control
Require: Symcon >= 6.0
The smart Water Control offers various services in IP-Symcon, which make it possible, for example, to recognize the status of the device or to switch the valve.
Services
An instance can be created for each service with the configurator.
| Service | Description |
| General | Contains general information about the device |
| Valve | Represents the valve of the irrigation control |
| Main valve | The main valve with which all valves can be closed |
General
The following status variables are created for this instance
| Variable | Type | Description |
| Battery status | String | The status of the device's battery |
| RF Link Level | Integer | The quality of the wireless connection in percent |
| RF Link Status | String | The status of the device's wireless connection |
Valve
| Activity | String | The current activity of the device |
| Remaining | Integer | The time remaining in seconds until the valve is closed |
| Error code | String | The last error transmitted |
| Status | String | The current state of the device |
| Open duration | Integer | The duration for which the valve is to be opened manually |
| Action | String | Allows the valve to be opened or closed for a specific opening period |
The following actions are available for this instance
| Action | Parameters | Description |
| Open valve | Duration (minutes) | Allows the valve to be opened for a certain period of time |
| Close valve | (none) | Allows the valve to close |
Main Valve
| Name | Type | Description |
| Action | String | Closes all valves |
| Close main valve | (none) | Allows the main valve to close |
