MA2_WriteValue
Require: Symcon >= 4.0
 boolean MA2_WriteValue (int $InstanceID, string $Ident, variant $Value)
ID of the Instance
Ident
Ident of the variable
Value
Value of the variable
Writes the Value Value into the variable with the Ident Ident in the Möhlenhoff Alpha 2 with the InstanceID InstanceID.
MA2_WriteValue(12345 , "HEATAREA1_T_TARGET", 23.3);
