S7_Write
boolean S7_Write (int $InstanceID, float $Value)
| Value | 32-bit floating point value according to IEEE754 or integer |
Writes the value Value to the configured address of the instance with the ID InstanceID without knowing the exact data type.
This function also supports setting values when a factor has been set.
This function cannot be used for bit values. S7_WriteBit must be used for bit values.
// Float value
S7_Write(12345, 23.5);
// Integer
S7_Write(12345, 123);
