System Variables
System variables are variables that are available in every PHP script. The user can utilize them to create efficient PHP scripts that can solve generic tasks. The according system variables are set automatically when the PHP script is called, depending on the trigger. The following tables providing an overview over the variables which are available in which PHP scripts.
Regard upper and lower case when writing these variables (Case Sensitive)!
General System Variables
The following system variables are always available.
System Variable Description
$_IPS['SELF'] ScriptID of the current PHP script
$_IPS['THREAD'] ThreadID of the current PHP script
$_IPS['SENDER'] Trigger of the current PHP script. Further global variables are possible, depending on the value. Possible values are further specified at Additional System Variables
The following system variables are available, depending on the value of $_IPS['SENDER'].
Action
When the PHP script was executed by a RequestAction .
system variable description
$_IPS['SENDER'] By default, this "Action" can be set individually with RequestActionEx
$_IPS['VALUE'] Value with which the variable was called
$_IPS['VARIABLE'] ID of the variable that is to be switched
Execute
When the PHP script was run from the administration console.
No additional system variables.
HeatingControl
When the PHP script was called from an event of HeatingControl.
$_IPS['INSTANCES'] IDs of the sending instances
$_IPS['INVERTS'] States if a device is inverted (true/false)
$_IPS['VALUE'] States if a device should heat (true) or not (false)
RegisterVariable
When the PHP script was called by a RegisterVariable instance.
$_IPS['INSTANCE'] ID of the triggering RegisterVariable instance
$_IPS['VALUE'] Value of the puffer that was received from the splitter or I/O module
$_IPS['CLIENTIP'] (only for I/O ServerSocket) Received IP adress of the Client
$_IPS['CLIENTPORT'] (only for I/O ServerSocket) Receiving port of the Client
$_IPS['TYPE'] Status of the receiving port (0 = Data; 1 = Connected; 2 = Disconnected)
RunScript
When the PHP script was called by an IPS_RunScript function. In addition, IPS_RunScriptEx can be called to pass additional parameters.
Shutdown
During IP-Symcon Shutdown (see EventControl).
No additional variables.
ShutterControl
When the PHP script was called by a ShutterControl Module.
$_IPS['DIRECTION'] Moving direction:
0 = Stop
1 = Up
2 = Down
$_IPS['DURATION'] Moving duration in milliseconds
$_IPS['INSTANCE'] InstanceID that was set in ShutterControl
$_IPS['INSTANCE2'] InstanceID #2 that was set in ShutterControl
Startup
During IP-Symcon Startup (see EventControl).
StatusEvent
When the PHP script is called by a state change of an instance.
Further informations are found at EventControl and IPS_GetInstance.
$_IPS['INSTANCE'] InstanceID for state change
$_IPS['STATUS'] State of the instance. A list of possible values is found here: IPS_GetInstance
$_IPS['STATUSTEXT'] A short text according to the state
TimerEvent
When the PHP script was called by a cyclic or a schedule event.
$_IPS['ACTION'] ID of the calling action (only schedule event)
$_IPS['EVENT'] ID of the triggered event
$_IPS['TARGET'] ID of the superior object
Variable
When the PHP script was called be a trigger event.
$_IPS['EVENT'] ID of the calling event
$_IPS['OLDCHANGED']
(since Version 5.1)
Timestamp of the last change of the old value
$_IPS['OLDVALUE'] Value of the affected variable before switching
$_IPS['OLDUPDATED']
(since Version 5.1)
Timestamp of the last update of the old value
$_IPS['TRIGGER'] Type of the calling event
$_IPS['VALUE'] Value of the affected variable when switching
$_IPS['VARIABLE'] ID of the affected variable
VoIP (since Version 5.2)
When the PHP script is executed by an event of the VoIP Module
$_IPS['CONNECTION'] ChannelID of the connection
$_IPS['DATA'] Contains the pressed button when $_IPS['EVENT'] is DTMF
$_IPS['EVENT'] The variable can contain the following values:
Incoming: Incoming call
Connect: Established connection
Disconnect: Terminating connection
PlayFinish: Audio file has finished playing
DTMF: Received a DTMF sound
$_IPS['INSTANCE']
(ab Version 5.4)
InstanceID of the VoIP Instance
Watchdog
When the PHP script is called by the Watchdog.
$_IPS['STATUSTEXT'] The passed state text
$_IPS['VALUE'] Value of the variable that is outside of its interval
$_IPS['VARIABLE'] ID of the variable that is outside of its interval
WebFront
When the PHP script was called by the WebFront, Tile Visualization, or IPSView.
$_IPS['CONFIGURATOR'] ID of the currently used visualization
$_IPS['VALUE'] (only for action script) New value of the variable
$_IPS['VARIABLE'] (only for action script) ID of the changing variable
WebHook (since Version 4.0)
When the PHP script was called by a WebHook control.
$_SERVER['HOOK'] Complete URL of the called WebHook
Furthermore, the WebHook type provides the same variables as WebInterface.
WebOAuth (since Version 4.0)
When the PHP script was called by a OAuth Control.
$_SERVER['OAUTH'] Complete URL of the called WebOAuth
Furthermore, the WebOAuth type provides the same variables as WebInterface.
WebInterface
When the PHP script was called by the Webserver, e.g., in the 'user' folder.
$_IPS['INSTANCE'] ID of the calling Webserver instance
$_GET Received data via GET
$_POST Received data via POST
$_SERVER['DOCUMENT_ROOT'] Contains the Document Root folder that contains the currently executed PHP script as it is set within the configuration of the server.
$_SERVER['PHP_AUTH_PW'] If HTTP authentication is used, this variable contains the password the user provided
$_SERVER['PHP_AUTH_USER'] If HTTP authentication is used, this variables contains the user name the user provided
$_SERVER['PHP_SELF'] File/Path of the started PHP script
$_SERVER['QUERY_STRING'] If available, the query string that was used to access the website
$_SERVER['REMOTE_ADDR'] The IP adress that the user used to access the website
$_SERVER['REMOTE_PORT'] The port that the user used to access the website
$_SERVER['REQUEST_METHOD'] Contains the request method that was used for the access, e.g., "GET", "HEAD", "POST", or "PUT"
$_SERVER['REQUEST_URI'] The URI that was used to access the current website, e.g., "/index.html"
$_SERVER['SCRIPT_NAME'] Contains the path of the current PHP script. This can be useful for websites that link to themselves
In addition, all request headers are added in capital letters with a HTTP* prefix. Minus symbols (-) are changed to underscore symbols (). For example, the header 'User-Agent is provided as $_SERVER['HTTP_USER_AGENT'].
