smart Pressure Pump
Require: Symcon >= 6.0
The smart Pump offers various services in IP-Symcon which, for example, enable the status of the device to be recognized or the valve to be switched.
Services
An instance can be created for each service with the configurator.
| Service | Description |
| General | Contains general information about the device |
| Valve | Represents the valve of the pump |
| Main valve | The main valve with which all valves can be closed |
General
The following status variables are created for this instance
| Variable | Type | Description |
| Battery status | String | The status of the device's battery |
| RF Link Level | Integer | The quality of the wireless connection in percent |
| RF Link Status | String | The status of the device's wireless connection |
Valve
| Activity | String | The current activity of the device |
| Remaining | Integer | The time remaining in seconds until the valve is closed |
| Error code | String | The last error transmitted |
| Status | String | The current state of the device |
| Open duration | Integer | The duration for which the valve is to be opened manually |
| Action | String | Allows the valve to be opened or closed for a specific opening period |
The following actions are available for this instance
| Action | Parameters | Description |
| Open valve | Duration (minutes) | Allows the valve to be opened for a certain period of time |
| Close valve | (none) | Allows the valve to close |
Main Valve
| Name | Type | Description |
| Action | String | Closes all valves |
| Close main valve | (none) | Allows the main valve to close |
