HM_ReadServiceMessages
array HM_ReadServiceMessages (int $InstanceID)
| InstanceID | ID of the HomeMatic Socket Instance |
The following information are available as key => value pairs:
| Address | string | Address of the relevant device |
| Message | string | Cryptic description of the error message. Text can be found partially in the stringtable_de.txt from the Home Automatic configuration tool. |
| Value | variant | Value of the error message |
Reads the service news of the CCU/ LAN adapter with the ID InstanceID.
//Creates a variable that displays all service messages in the Visualization. Copy in a script and run.
//From here change anything
$object = IPS_GetObject($_IPS['SELF']);
$parentID = $object['ParentID'];
//Installer
if ($_IPS['SENDER'] == "Execute")
IPS_SetHidden($_IPS['SELF'], true);
IPS_SetName($_IPS['SELF'], "Script");
$parentObject = IPS_GetObject($parentID);
if ($parentObject['ObjectType'] !== 1)
$instanceID = IPS_CreateInstance("{485D0419-BE97-4548-AA9C-C083EB82E61E}");
IPS_SetParent($instanceID, $parentID);
$parentID = $instanceID;
IPS_SetParent($_IPS['SELF'], $parentID);
IPS_SetName($instanceID, "Servic messages");
IPS_SetScriptTimer($_IPS['SELF'], 300);
$texte = Array(
"CONFIG_PENDING" => "Configuration data are due for transfer",
"LOWBAT" => "Low battery condition",
"STICKY_UNREACH" => "Device communication was disrupted",
"UNREACH" => "Disrupted communication devices currently"
$str = "<table width='90%' align='center'>"; // Adjust color or remove style
$str .= "<tr><td><b>Gerätname</b></td><td><b>GeräteID</b></td><td><b>Meldung</b></td></tr>";
$ids = IPS_GetInstanceListByModuleID("{A151ECE9-D733-4FB9-AA15-7F7DD10C58AF}");
if(sizeof($ids) == 0)
die("No HomeMatic Socket instance found!");
$msgs = HM_ReadServiceMessages($ids[0]);
if($msgs === false)
die("Connect to the CCU failed");
if(sizeof($msgs) == 0)
$str .= "<tr><td colspan=3><br/>No service messages!</td></tr>";
foreach($msgs as $msg)
if(array_key_exists($msg['Message'], $texte)) {
$text = $texte[$msg['Message']];
} else {
$text = $msg['Message'];
$id = GetInstanceIDFromHMID($msg['Address']);
if(IPS_InstanceExists($id)) {
$name = IPS_GetLocation($id);
} else {
$name = "Device is not set up in IP Symcon";
$str .= "<tr><td>".$name."</td><td>".$msg['Address']."</td><td>".$text."</td></tr>";
$str .= "</table>";
$vid = CreateVariableByName($parentID, "Content", 3);
IPS_SetIcon($vid, "Information");
IPS_SetVariableCustomProfile($vid, "~HTMLBox");
SetValue($vid, $str);
function GetInstanceIDFromHMID($sid)
$ids = IPS_GetInstanceListByModuleID("{EE4A81C6-5C90-4DB7-AD2F-F6BBD521412E}");
foreach($ids as $id)
$a = explode(":", HM_GetAddress($id));
$b = explode(":", $sid);
if($a[0] == $b[0])
return $id;
return 0;
function CreateVariableByName($id, $name, $type)
if($vid === false)
IPS_SetParent($vid, $id);
IPS_SetName($vid, $name);
IPS_SetInfo($vid, "this variable was created by script #".$_IPS['SELF']);
return $vid;
