HM_WriteValueBoolean
boolean HM_WriteValueBoolean (int $InstanceID, string $Parameter, boolean $Value)
| Parameter | Parameter that should be set. The name of the parameter can be taken from the data point list or as "Ident" in the tab "Status Variables" in IP-Symcon. |
| Value | true or false |
Additional datapoints can be taken from the HomeMatic data point list.
If the error message Failure occurs, this is usually due to a bad wireless connection.
// Switch device on
HM_WriteValueBoolean(12345, "STATE", true);
// Lock device
HM_WriteValueBoolean(12345, "INHIBIT", true);
// Switch on display light
HM_WriteValueBoolean(12345, "BACKLIGHT", true);
