Device list
Supported Gateways
| Product | Description |
| Symcon Z-Wave-Plus LAN Gateway | Product information | IP Gateway |
| 300ZW-US-W | TrickleStar USB Stick |
| AEO_USB | USB stick from Aeon Labs |
| ZW090 | USB Z-Stick from Aeotec |
| RaZberry | Z-Wave Transceiver for Rasperrry PI |
| VIS_ZU1401 | Vision USB stick |
| ZME_Serial | Serial adapter plate |
| ZME_UZB1 | USB stick |
| ZME_ZSTICKC | Z-Wave.Me USB stick |
Devices
All listed command classes are supported by IP-Symcon. In addition, we offer a list of devices which have been successfully tested by us or our customers.
On request we will be happy to check other devices that are not listed for their compatibility.
Supported Command Classes
Each Z-Wave device has different Command classes. These classes indicate which functions are supported by the respective device. In IP-Symcon, all functions are available with the following listed command classes.
| Command Class | Class Version | IP-Symcon Version |
| ALARM | ------------- | Replaced by NOTIFICATION |
| ASSOCIATION | 2 | |
| ASSOCIATION_GRP_INFO | 2 | since 5.1 |
| BASIC | 2 | |
| BASIC_WINDOW_COVERING | 1 | |
| BATTERY | 1 | |
| CENTRAL_SCENE | 1 | since 4.1 |
| CLOCK | 1 | |
| COLOR | 1 | since 4.1 |
| CONFIGURATION | 1 | |
| CRC_16 | 1 | |
| DOOR_LOCK | 2 | since 4.1 |
| LOCK | 2 | |
| MANUFACTURER_SPECIFIC | 2 | |
| METER | 5 | |
| MULTI_CHANNEL | 4 | |
| MULTI_CHANNEL_ASSOCIATION | 3 | since 5.1 |
| MULTI_CMD | 1 | |
| MULTI_INSTANCE | ------------- | Replaced by MULTI_CHANNEL |
| NOTIFICATION | 8 | since 4.3 |
| PROTECTION | 2 | |
| SCENE_ACTIVATION | 1 | since 4.1 |
| SECURITY | 1 | since 4.1 |
| SENSOR_ALARM | 1 | |
| SENSOR_BINARY | 2 | |
| SENSOR_MULTILEVEL | 11 | |
| SWITCH_ALL | 1 | since 4.1 |
| SWITCH_BINARY | 2 | |
| SWITCH_MULTILEVEL | 4 | |
| SWITCH_SHUTTER | 1 | |
| THERMOSTAT_FAN_MODE | 1 | |
| THERMOSTAT_FAN_STATE | 1 | |
| THERMOSTAT_MODE | 1 | |
| THERMOSTAT_OPERATING_STATE | 1 | |
| THERMOSTAT_SETPOINT | 1 | |
| TIME | 2 | since 4.1 |
| USER_CODE | 1 | since 4.1 |
| Unknown | 1 | |
| VERSION | 2 | |
| WAKE_UP | 2 | |
| ZWAVEPLUS_INFO | 2 | since 5.1 |
Tested components
sorted by alphabet
ACT
| ZRM230 | Wall Switch/Transmitter (2-gang) |
| ZTM230 | RF Wall Transmitter (2-gang) |
Aeon Labs
| AEO_DSC20-EU | Door/Window Sensor |
| AEO_DSB54 | Recessed Door Sensor |
| AEO_DSD31 | Siren |
| AEO_EXTENDER | Extender |
| AEO-HEM2, HEM3 | Clamp Meter 40 |
| AEO_KFOB | Key Fob |
| AEO-MEI | Micro Dimmer |
| AEO-MES | Micro Switch |
| AEO-MSEI | Micro Smart Energy Dimmer |
| AEO-MSES | Micro Smart Energy Switch |
| AEO_MULTISENS | Multisensor |
| AEO-SES3 | Smart Energy Switch 3 |
| AEO_ZW088 | Key Fob Gen 5 |
| AEO_ZW089 | Recessed Doorsensor |
| DSD31 | Outlet Plugable Siren |
AeoTec
| ZW078 | Heavy Duty Smart Switch |
| ZW080 | Siren 5 |
| ZW095 | Home Energy Meter |
| ZW096 | Smart Switch 6 |
| ZW100 | MultiSensor 6 |
| ZW111 | Nano Dimmer |
| ZW112 | Door/Window Sensor 6 |
| ZW116 | Nano Switch with Power Metering |
| ZW117 | Range Extender 6 |
| ZW120 | Door/Window Sensor Gen5 with Tamper Sensor |
| ZW121 | LED Strip |
| ZW122 | Water Sensor 6 |
| ZW129 | WallMote |
| ZW130 | WallMote Quad |
| ZW132 | Dual Nano Switch with Power Metering |
| ZW139 | Nano Switch |
| ZW140 | Dual Nano Switch |
| ZW141 | Nano Shutter |
| ZW158 | WallSwipe |
| ZW160 | Water Sensor 6 Dock |
| ZW162 | Doorbell 6 |
| ZW166 | Button |
| ZW164 | Siren 6 |
| ZW175 | Smart Switch 7 |
| ZW189 | Range Extender 7 |
| ZWA001 | LED Bulb 6 Multi-White |
| ZWA002 | LED Bulb 6 Multi-Colour |
| ZWA003 | NanoMote Quad |
| ZWA004 | NanoMote One |
| ZWA005 | TriSensor |
| ZWA006 | Smart Boost Timer Switch |
| ZWA008 | Door/Window Sensor 7 |
Danfoss
| DAN_LC-13 (014G0013) | Thermostat Radiator Valve |
| DAN_LIVC_RAK (014G0012) | Thermostat Radiator Valve |
Everspring
| EVR_AD142 | Dimmer Plug |
| EVR_AN145 | Screw-In Lamp Holder |
| EVR_AN157 | On/Off Plug |
| EVR_AN158 | On/Off Plug with power meter |
| EVR_HSM02 | Door/Window Detector |
| EVR_HSP02 | Motion Detector |
| EVR_SE812 | Siren |
| EVR_SF812 | Smoke Detector with Alarm |
| EVR_SP103 | Motion Sensor |
| EVR_SP814 | Motion Detector |
| EVR_ST812 | Flood Sensor |
| EVR_ST814 | Temperature & Humidity Sensor |
Fibaro
| FGBS-001 | Universal Binary Sensor |
| FGD-211 | Universal Dimmer |
| FGFS-101 | Flood Sensor |
| FGK 101-107 Door/Window Sensor 2.5 | Door/Window Sensor |
| FGK-001 | Door/Window Sensor |
| FGMS-001 | Motion Sensor |
| FGRGB-101 | RGBW Controller |
| FGRGBWM-441 | RGBW Controller |
| FGRM-222 | Roller Shutter 2 |
| FGS-211 | 1x3KW Relay |
| FGS-221 | 2x1.5KW Relay |
| FGSS-001 | Smoke Sensor |
| FGSS-101 | Smoke Sensor |
| FGWPE/F-101 | Wall Plug |
NorthQ
| Energy Guard Electrical Meter | Meter (incomplete support) |
| Energy Guard Gas Meter | Gas Meter (incomplete support) |
Philio
| In Wall Dual Relay (1 Way) | 230VAC powered static controller with binary switch capability |
| In Wall Dual Relay(1 Way) | In-wall switch module |
| In Wall Dual Relay(1 Way) | In-wall dual relay switch module |
| In Wall Single Relay(1 way) | In-wall switch module |
| PAN04 | 2 x 1.5Kw Relay with Power Measurement |
| PAN06 | 2 x 1.5Kw Relay |
| PAN08 | In-Wall Roller Shutter Controller |
| PAN11-1 | Plugin Switch with meter functionality PAN11-1 |
| PAT02-1A | Flood multisensor (flood, temperature and humidity) |
| PSE02 | Wireless multiple sound siren |
| PSG01 | Smoke Sensor |
| PSM01 | 3-in-1 Sensor (Door, Light, Temp) |
| PSM02 | 4-in-1 Sensor (PIR, Door, Light, Temp) |
| PSM02-1 | PIR, door/window, temperature and illumination Sensor |
| PSP01 | 3-in-1 Sensor (PIR, Light, Temp) |
| PSR03 | Remote |
| PST02 | Slim Multisensor |
Polycontrol
| Danalock Circle | Z-Wave Door Lock |
| Danalock Square | Z-Wave Door Lock |
Popp
| POP_004308 | Smoke Detector and Temp Sensor |
| POP_123610 | Plug-in Switch |
| POP_123658 | Plug-in Switch with Meter |
| POP_123665-58 | Wall Plug Switch/Meter |
| POP_123xxx | On/Off Plug |
| POP_123xxx | Dimmer Plug |
Vision
| PIR Sensor | PIR Motion Sensor |
| Plugin ON/OFF | Light Relay |
| Power Monitor | Power Monitor |
| VIS_ZD2102EU 2013 | Door Window Sensor with external digital input |
| VIS_ZD3102EU 2013 | Motion detector with Temperature sensor and temper protection |
| VIS_ZG8101 | Garage Door Detector |
| VIS_ZL7432 | In-Wall Dual Relay Switch |
| VIS_ZM1601 | Siren (Battery) |
| VIS_ZM1602 | Siren (Mains) |
| VIS_ZS5102 | Shock & Vibration Sensor |
| VIS_ZS6101 | Smoke Detector |
| VIS_ZS6301 | CO Detector |
Zipato
| Mini Keypad RFID/Z-Wave | Mini Keypad with RFID support |
| RGBW bulb | RGBW Bulb |
Z-Wave.ME
| Mini remote control KFOB | Mini remote control 4 buttons Z-Wave KFOB, Version 2 Z-WAVE.ME |
Other
| Manufacturer | Product | Description |
| Express Control | EZMotion | Motion detector, luminosity and temperature sensor |
The following are the currently definitely unsupported devices
Non-supported components
sorted by alphabet
Merten
| All | Almost all Merten products cannot be addressed via the normal Z-Wave standard |
