Popup Module
Require: Symcon >= 4.0
The Popup Module is an instance that does not contain its own function or status variables. The module can be used as a stylistic means to display objects within a popup.
Installation
The module is part of Symcon and does not need to be installed.
Setting up the instances in Symcon
The "Popup Module" module can be found under "Add instance" using the quick filter. Further information in the documentation of the instances.
The module has no configuration page. The variables and objects are created in the object tree beneath the instance.
Application
Several objects belong to a subject group, which should only be viewed quickly when required. In order to display the objects in the popup, they must be copied into the popup instance themselves or via a link.
Visualization
How the module is displayed can be seen here:
Popup display
In the mobile apps, the popup instance has the same representation as a Dummy Module, as these do not allow nesting.
