Require: IP-Symcon >= 5.2
boolean VoIP_PlayWave (int $InstanceID, int $ConnectionID, string $Filename)
ConnectionID | ID of the connection to be switched |
Filename | Path and name of the file to be played |
Plays the sound file Filename on the connection with the ID ConnectionID on the VoIP instance with the ID InstanceID.
Exclusively data in WAV format: 16-bit, 8000 Hz, mono is supported.
It does not wait for the sound file to finish playing. This is handled by the $_IPS['EVENT'] == "PlayFinish".
Dynamic sound files can also be created using the TTS Module or AWS Polly from the Module Store.
// Plays the sound file "welcome.wav" on the connection with ID 3
VoIP_PlayWave(12345, 3, IPS_GetKernelDir() . "/media/welcome.wav");
