UC_FindReferences
 array UC_FindReferences (int $InstanceID, int $ID)
ID for the Util Control
ID
ID of the object whose usages are searched
An array with one entry per location. Each entry contains the following key => value pairs:
Index Type Description
LineContent string For scripts the found line without leading and trailing spaces, otherwise the kind of location (see table)
LineNumber integer For scripts the line number (starting at 1), otherwise 0
LinePosition integer For scripts the position of the first match in the line in bytes (starting at 0), otherwise 0
ObjectID integer ID of the object that uses ID
The function searches the entire system for places where the object ID is used, e.g. before a variable is deleted or replaced. The management console uses it to show the usages of an object. The following locations are recognized, in this order:
LineContent ObjectID Location
(line of the script) Script The script content contains ID as text. One entry per line, LineNumber and LinePosition are set
Variable Variable ID is the custom action (action script) of the variable
Event (Action) Event A parameter of the action of the event or of an action of the weekly schedule contains ID as text
Event (Condition) Event A condition of the event checks the variable ID or compares with it
Event Event ID is the triggering variable of the triggered event
Link Link ID is the target of the link
Instance Instance The instance has ID in its reference list (see IPS_GetReferenceList)
Instance (Connected) Instance The instance is connected to the instance ID as its parent
IPSView Media object (IPSView) The IPSView file uses ID
Chart Media object (Chart) A dataset of the chart uses the variable ID
The name in LineContent may be translated into the language of the system. An object can appear several times in the result, e.g. a script with several matches or an event with several matching conditions. If nothing is found, the result is an empty array. Whether ID exists is not checked. Searching for the root (ID 0) is not possible and fails with "Search ID cannot be 0".
Scripts and action parameters are searched as text. Searching for 12345 therefore also finds 123456 or a number 12345 that is not an object ID at all. Conversely, IDs that a script only determines at runtime, e.g. with IPS_GetObjectIDByIdent, are not found.
Since all script files are read, the search can take some time in large systems.
// Output all usages of the variable 12345
foreach (UC_FindReferences($id, 12345) as $reference) {
    if ($reference['LineNumber'] > 0) {
        echo IPS_GetName($reference['ObjectID']) . ', line ' . $reference['LineNumber'] . ': ' . $reference['LineContent'] . PHP_EOL;
    } else {
        echo IPS_GetName($reference['ObjectID']) . ' (' . $reference['LineContent'] . ')' . PHP_EOL;
