UC_GetLogMessageStatistics
array UC_GetLogMessageStatistics (int $InstanceID)
| InstanceID | ID for the Util Control |
An array with the following key => value pairs:
| MessageCustomCount | integer | Number of messages of type KL_CUSTOM (e.g. from IPS_LogMessage) |
| MessageDefaultCount | integer | Number of messages of type KL_MESSAGE |
| MessageErrorCount | integer | Number of messages of type KL_ERROR |
| MessageNotifyCount | integer | Number of messages of type KL_NOTIFY |
| MessageSuccessCount | integer | Number of messages of type KL_SUCCESS |
| MessageTimeStamp | integer | Sequence number of the last message (of any type) processed by the Util Control. Not a timestamp! |
| MessageWarningCount | integer | Number of messages of type KL_WARNING |
| ResetTimeStamp | integer | Unix timestamp from which counting starts (start of IP-Symcon or last call of UC_ResetLogMessageStatistics) |
The function returns how many messages per message type have been written to the log since ResetTimeStamp. For this purpose, the Util Control receives all messages of the kernel and counts the log messages. The counters can be queried regularly, e.g. to detect whether new errors or warnings have occurred. The last messages themselves are returned by UC_GetLastLogMessages, the counters are reset with UC_ResetLogMessageStatistics.
Only messages that occur while IP-Symcon is ready are recorded (not during startup and shutdown). Debug messages (KL_DEBUG) are not forwarded and are therefore never recorded, neither are messages that are filtered out by the special switch "LogfileFilter".
Despite its name, MessageTimeStamp is not a timestamp. The kernel numbers all messages it distributes consecutively since the start (1, 2, 3, ...). MessageTimeStamp is the number of the last message processed by the Util Control and changes with every message, not only with log messages. If no messages are waiting to be processed, the value roughly equals MessageCounter of UC_GetKernelStatistics. It is not reset by UC_ResetLogMessageStatistics.
print_r(UC_GetLogMessageStatistics($id));
/* e.g. returns:
Array
[MessageCustomCount] => 0
[MessageDefaultCount] => 0
[MessageErrorCount] => 2
[MessageNotifyCount] => 0
[MessageSuccessCount] => 1
[MessageTimeStamp] => 184
[MessageWarningCount] => 1
[ResetTimeStamp] => 1700000000
