UC_ResetLogMessageStatistics
 bool UC_ResetLogMessageStatistics (int $InstanceID)
ID for the Util Control
The function sets all counters of UC_GetLogMessageStatistics to 0 and ResetTimeStamp to the current time. Afterwards only what is written to the log from this point on is counted.
MessageTimeStamp remains unchanged. The stored messages of UC_GetLastLogMessages are kept as well, they are cleared with UC_ResetLastLogMessages.
UC_ResetLogMessageStatistics($id);
// Count anew from now on
echo 'Counting since ' . date('d.m.Y H:i:s', UC_GetLogMessageStatistics($id)['ResetTimeStamp']);
