UC_GetIconList
array UC_GetIconList (int $InstanceID)
| InstanceID | ID for the Util Control |
An array with the names of the icons (without file extension).
The function returns the names of all icons that come with IP-Symcon. For this purpose, the SVG files in the directory "webfront/img/icons" of the installation are read. The names can be used e.g. with IPS_SetIcon. The sub-icons of adaptive icons (name with "-", e.g. "Battery-50") are not included. The order of the entries is not defined. If the directory does not exist, the result is an empty array.
The icons including their content and the icons of the skins are returned by IPS_GetIcons.
print_r(UC_GetIconList($id));
/* e.g. returns:
Array
[0] => Aircraft
[1] => Alert
[2] => ArrowRight
[3] => Backspace
[4] => Basement
