UC_GetMessageSenderIDList
array UC_GetMessageSenderIDList (int $InstanceID)
| InstanceID | ID for the Util Control |
An array with one entry per sender that has sent a message since the start. Each entry contains the following key => value pairs:
| Count | integer | Number of messages of this sender |
| SenderID | integer | ID of the object that caused the message (0 = kernel or no object) |
The function counts all messages distributed by the kernel, separated by the sender. The sender is the object the message refers to, e.g. the variable for a variable update or the instance for a status change. This allows to find objects that create an unusually large number of messages, e.g. a variable that is updated several times per second. The amount of data per sender is returned by UC_GetMessageSenderIDSizeList, the distribution among the message types by UC_GetMessageTypeList.
The values are summed up in memory since the start of IP-Symcon and cannot be reset (only a restart starts again at 0). The order of the entries is not defined.
// Output the three most active senders
$list = UC_GetMessageSenderIDList($id);
usort($list, function ($a, $b) {
return $b['Count'] <=> $a['Count'];
foreach (array_slice($list, 0, 3) as $entry) {
echo $entry['SenderID'] . ': ' . $entry['Count'] . PHP_EOL;
/* e.g. returns:
0: 26
10008: 25
10012: 11
