UC_ResetLastLogMessages
 bool UC_ResetLastLogMessages (int $InstanceID)
ID for the Util Control
The function clears the buffers of all message types whose content is returned by UC_GetLastLogMessages. Afterwards UC_GetLastLogMessages only returns messages that were written to the log after the call. The log or the log files themselves are not changed.
The counters of UC_GetLogMessageStatistics are kept, they are reset with UC_ResetLogMessageStatistics.
UC_ResetLastLogMessages($id);
// Now returns an empty array until another error message occurs
print_r(UC_GetLastLogMessages($id, KL_ERROR - KL_MESSAGE));
