UC_GetEventStatistics
 array UC_GetEventStatistics (int $InstanceID)
ID for the Util Control
An array with the following key => value pairs:
Index Type Description
CyclicUpdateCount integer Number of updates of cyclic events and weekly schedules
TriggerUpdateCount integer Number of executions of triggered events
The function evaluates the message EM_UPDATE, which an event sends after each execution and on each recalculation of its next run time, and assigns it by the type of the event. Triggered events only send the message when they are executed, so TriggerUpdateCount counts their executions. Cyclic events and weekly schedules count towards CyclicUpdateCount, also when their next run time is recalculated without an execution, e.g. when they are activated, deactivated or their schedule is changed.
If one of the values grows strongly between two queries, a very large number of events is executed, e.g. triggered events on a variable that is updated very frequently. The values are summed up in memory since the start of IP-Symcon and cannot be reset (only a restart starts again at 0).
print_r(UC_GetEventStatistics($id));
/* e.g. returns:
Array
    [CyclicUpdateCount] => 0
    [TriggerUpdateCount] => 0
