UC_GetLastLogMessages
array UC_GetLastLogMessages (int $InstanceID, int $Type)
| InstanceID | ID for the Util Control |
| Type | Message type from 0 to 6 (see table in the description) |
An array with one entry per message, starting with the oldest one. Each entry contains the following key => value pairs:
| Message | string | Text of the message |
| Sender | string | Name of the sender, e.g. "Kernel" or the module name. Shorter names are padded with spaces to 20 characters |
| SenderID | integer | ID of the sender, e.g. the InstanceID for messages of instances. 0 for messages of the kernel and from IPS_LogMessage |
| TimeStamp | integer | Unix timestamp of the message |
The function returns the messages of the message type Type that were written to the log most recently. For this purpose, the Util Control keeps a separate buffer in memory for each message type, which contains the last 25 messages. If another message is added, the oldest one is discarded. The number can be changed with the special switch "LogMessageCount"; the value is read when the instance is created, i.e. when IP-Symcon starts. After a restart the buffers are empty, UC_ResetLastLogMessages clears them as well.
| Type | Constant | Name in the log | Note |
| 0 | KL_MESSAGE | MESSAGE | |
| 1 | KL_SUCCESS | SUCCESS | |
| 2 | KL_NOTIFY | NOTIFY | |
| 3 | KL_WARNING | WARNING | |
| 4 | KL_ERROR | ERROR | |
| 5 | KL_DEBUG | DEBUG | Always empty, debug messages are not forwarded |
| 6 | KL_CUSTOM | CUSTOM | e.g. messages from IPS_LogMessage |
Type is not the message ID of the constant but its offset to KL_MESSAGE, e.g. KL_ERROR - KL_MESSAGE = 4. Values outside of 0 to 6, e.g. KL_ERROR directly, result in the error "Type must be between 0 and 6".
Only messages that occur while IP-Symcon is ready are recorded (not during startup and shutdown). Debug messages (KL_DEBUG) are not forwarded and are therefore never recorded, neither are messages that are filtered out by the special switch "LogfileFilter". The number of messages per type is returned by UC_GetLogMessageStatistics.
// Output all stored error messages
foreach (UC_GetLastLogMessages($id, KL_ERROR - KL_MESSAGE) as $message) {
echo date('d.m.Y H:i:s', $message['TimeStamp']) . ' | ' . trim($message['Sender']) . ' | ' . $message['Message'] . PHP_EOL;
print_r(UC_GetLastLogMessages($id, KL_SUCCESS - KL_MESSAGE));
/* e.g. returns:
Array
[0] => Array
[Message] => *** IPS READY
[Sender] => Kernel
[SenderID] => 0
[TimeStamp] => 1700000000
