Network and security
Require: Symcon >= 5.1
Supplement to HomeMatic CCU: authentication and firewall of the CCU and the operation of Symcon with QNAP, Synology or Docker.
Firewall-, Authentication- and Port Settings
Authentication is possible with a CCU3 or RaspberryMatic in combination with IP-Symcon 5.1 or above.
This can be set in the web interface of the CCU. Authentication can be activated under "Settings" -> "Control Panel" -> "Security". This then uses the users that are set in the user administration.
HomeMatic: Authentication of the CCU
Furthermore, the firewall can be set up under "Settings" -> "Control Panel" -> "Configure Firewall". Further information can be found in the CCU manual.
HomeMatic: CCU configuration
HomeMatic with QNAP, Synology or Docker
If HomeMatic is to be used with QNAP, Synology or Docker, NAT support must be set up to receive responses from the system. This process is explained here.
