What can we improve?
(Edit)
VoIP_Disconnect
Require: IP-Symcon >= 5.2
 boolean VoIP_Disconnect (int $InstanceID, int $ConnectionID)
ConnectionID
ID of the connection to be switched
Disconnects the VoIP instance with ID InstanceID from the connection with ID ConnectionID.
// Disconnects with ID 3 of the instance with ID 12345
VoIP_Disconnect(12345, 3);
